Ben®
08.03.2009, 14:34
Aus Lugnet Trains kopiert:
From the LEGO Group:
Dear all,
As promised in the second communication from the 6th of December last year, we will give you the latest information and decisions regarding the development of the new train system based on LEGO Power Functions. We are still working on the final details and doing a lot of testing of the new Power Functions elements; however, we are again able to give you some more details. First - we will not change the gauge of the rails so there is no need to be afraid that the L gauge will disappear. On the rechargeable battery box we have been working to get the best compromise between size and power. It has been decided that we will use a powerful Lithium Polymer battery and the size of the box will be 4 studs by 8 studs long by 4 studs high - this should fit in most trains. The already existing standard LEGO transformer will be used to recharge and be the power supply. The existing Power Functions RC receiver already has integrated speed control. To enable the use of this we will make a newly designed RC handset with speed control capability. All the above new train related Power Functions items as well as the current battery train motor (with cross axles and wheels) will be available separately through LEGO Shop@Home before the summer of 2009. As you know we arranged a train workshop in November 2007 where ten AFOLs from around the world: Denmark, USA, France, Belgium, the Netherlands Germany, and Untied Kingdom participated, built with the prototype elements and also looked into ideas and possibilities for new train designs using the Power Functions elements . Based on the outcome of this workshop and all the other fantastic input we got from the AFOL community over the last six months, our designers worked on the first train set using the new Power Functions system. This set will be truly aimed at the AFOL community to acknowledge the importance of the adult LEGO hobbyists in the LEGO train world. This communication will be the last one regarding the transition from the 9V train system into the new Power Functions train system, Due to all the very valuable AFOL feedback we are far down the road with the development of the new elements and also the new train set. We appreciate all your efforts through this transition which we expect to be fully executed in 2009. Stay tuned for the new LEGO train system coming in 2009.
Tormod Askildsen, Head of LEGO Community Development
Klingt vielversprechend, wie ich finde. Natürlich wird das mit den Akkus teuer, wenn man genug davon haben will, um ein Eisenbahnerwochenende am Laufen zu halten. Und was ist mit dem Flexgleis? Das fällt wohl unter "Stay tuned for the new LEGO train system"....
Leg Godt!
09.03.2009, 13:35
Lego
» ändert das Eisenbahnsystem ohnehin etwa alle 10 Jahre, und ein gutes
» Drittel ist schon rum.
Liebär Heiner!
Genua. Vor allem sollten sie dann die Umsatzverluste mitbärechnen.
Ich glaube ja fast, in den drei Jahren mit ohne 9V Schienen gab's so viel Rückgang, daß eine neue Metallblechbiegemaschine drin gewesen wäre.
greenman
09.03.2009, 17:36
Gruss,
Klaas
schaeng
09.03.2009, 23:48
Liebär Mich.a!
» ... , daß eine neue Metallblechbiegemaschine drin gewesen wäre.
nich die Blechbärarbeitung war das Problem, sondern die gebogenes-Blech-auf-Plastik-montier-Maschine.
A.bär die gibbet nich und Mich.a's Tatzen sind dafür zu grob,
feine flinke Finger find fonnöten, aber teuer!
Hans
Oversize
10.03.2009, 07:57
» A.bär die gibbet nich und Mich.a's Tatzen sind dafür zu grob,
» feine flinke Finger find fonnöten, aber teuer!
» Gruß
» Hans
Es gibt doch genug Kinder, die den ganzen Tag nur vor der Spielkonsole sitzen, lasst sie mal was sinnvolles tun, da haben wir alle was davon
Gruß Jürgen
brummer
10.03.2009, 09:25
Hallo Jürgen,
» Wir fahren jeweils 4 Züge seit Ende Januar im Miniland unter
» Dauereinsatz.
10.03.2009, 17:59
Lieber Hans!
Liebär Mich.a!
» » ... , daß eine neue Metallblechbiegemaschine drin gewesen wäre.
» nich die Blechbärarbeitung war das Problem, sondern die
» gebogenes-Blech-auf-Plastik-montier-Maschine.
Aha! Und ich dachte, das sei eine In-eins-Maschine.
Von der Mangelnden Gedudl gahnich erst zu reden!
Ich sage nur: Schina!
Apropos:
In einer hiesigen, dh: genauer gesagt: Osloer, Sonntagszeitung gab's n längeren Artikel über Lego und die Erfahrungen div. Halb-Promis* damit, sowie kurze Jubelszenen der beiden Norweger, di ein Billund arbeiten.
*Mit ohne:
Mich.a
» Gruß
» Hans
Jan.K
11.03.2009, 00:48
» Liebär Mich.a!
Die liefe dann ja wohl Gefahr, die allerallerallerteuerste Maschine im ganzen Kr... äh, Maschinenpark
zu werden - dabei leistet LEGO sich ja nicht einmal eine Maschine mit dem "Ping".
Jan
11.03.2009, 08:56
LLL!
Sach noch mal einer, ich schröbe kryptisk.
Kr..."Pling"???
Krachbumm kenne ich.
Krautgarten? Krisenpaket? Krawalladen?
Klingelton? Wiehernde Pferde? Chattanooga Cho Cho-Geräuschmacher?
UNchiffrierte Grüße
Hamster
11.03.2009, 11:30
Hallo Ralf,
» ABER:
» was macht die 9V-Fraktion mit dem Flex-Gleis
Links liegen lassen: 1. ist das Teil mehr als häßlich,
2. ist das Teil Blay,
3. müsste man dran rumbasteln.
» Jungs da haben wir wieder eine Herausforderung .... hat zufällig jemand
» dafür auch schon eine Idee ??? :|
So kann man die Sache natürlich auch sehen. Das ist aber nichts für mich.
» Spätestens wenn ich so ein Ding in die Finger bekomme ....
» größere (flex) Radien mit stromführenden Schienen .... das wär mir was
» Wert
Du kannst uns Deine Ergebnisse ja dann zeigen
Mit freundlichen Grüßen
Hamster
Jan.K
12.03.2009, 00:59
na, das ist doch (fast) Allgemeinbildung:
most expensive machine
mehr von dem Zeug: http://www.youtube.com/MontyPython
Jan
