HerosDA
14.07.2013, 07:06
+3Weihnachtsmarkt
Ages 12+. 1,261 pieces.
Collect and create a fun festive scene with the Winter Village Market!
US $99.99 - CA $129.99 - DE 89.99€ - UK 79.99 £ - DK 799.00 DKK
Bring home the holiday spirit with the Winter Village Market, continuing the popular LEGO® Winter Village Series. Turn the handle and take a ride on the rocking horse as the carousel spins! Visit the carnival booth. Fill up on holiday and fair favorites including a pie, pretzel and croissant at the baker’s stand, chicken and sausage at the grill stand or sweet treats at the candy shop. Celebrate a holiday season full of traditions and building with the Winter Village Market! Includes 9 minifigures with accessories: 3 females, 2 males and 4 children.
• Includes 9 minifigures with accessories: 3 females, 2 males and 4 children
• Features functioning carousel and operator’s booth with moving bucket challenge, baker’s stand, grill stand, candy stand, 2 streetlamps, 3 trees, a bench and 3 tables
• Accessories include cups, teddy bear, a cat, scarf, purse and lots of food elements
• Carousel horses feature new ornamental headwear design
• Turn the handle to make the carousel rotate
• Take a ride on the carousel
• Watch the carousel horses really rock!
• Fill up on holiday treats at the bakery, grill and candy stands!
• Carousel and operator’s booth measure 7" (19cm) high, 10" (25cm) wide and 6" (16cm) deep
• Booths measure over 3" (9cm) high, 3" (8cm) wide and 1" (4cm) deep
• Combine with 10229 Winter Village Cottage for an even bigger winter scene!
Available for sale directly through LEGO® beginning
October 2013 via shop.LEGO.com, LEGO® Stores or via phone:
Find den Preis mit 89,- aber glei wieder zu heftig
weis nicht wie ihr das seht
Legomaniac86 , Steinie , JuL gefällt das
17 vorhergehende Beiträge sind ausgeblendet
FlowRian
14.07.2013, 21:50
Re: dunkelblauer Bogenstein
Mich stört es ehrlich gesagt, dass dieser Stein nun an Wert verlieren wird.
Wenn die Monorail nun noch einmal käme, das wäre super - wird aber glaube ich niemals passieren.
legomadly88
15.07.2013, 17:13
+1Re: Weihnachtsmarkt
danke fürs posten.
Dieses Set ist gleich mal vorgemerkt, denn mir gefällt es. Lässt sich zwischen den anderen Sets bestimmt gut integrieren.
Vor allem das kleine Karussell gefällt mir. Es ist nicht so groß wie das 10196 ;)
Auch was den Preis betrifft, bin ich der Meinung das er in Ordnung geht.
XaverG gefällt das
Kiki
15.07.2013, 17:35
Als Antwort auf den Beitrag von legomadly88
Ich finde das kleine Karussell auch charmanter als das große. Im oben verlinkten Youtube-Video sieht man schön, wie die manuelle Drehbewegung beim jetzigen Set zustandekommt - hat ein bisschen etwas von Retro-Spielzeug, finde ich. Allein schon wegen dieses Nostalgie-Faktors wird das Set wohl bei mir einziehen.
XaverG gefällt das
Bricks4Jo
18.10.2013, 07:14
Dach liegt auf Spannung
Hallo, meine Frau hat gestern das Set zusammengebaut. Echt ein tolles Set, vor allem mit den gratis Zugaben. Uns ist aber beim Zusammenbau aufgefallen, dass das Dach der Ballwurfbude sehr auf Spannung liegt. Das scheint an dem Zahnradkonstruckt zu liegen, an der Stelle, an dem der Achs/Pin Verbinder in Tan auf der gelochten Platte aufliegt.
Hat das auch jemand bemerkt?
Mfg
Johannes
18.10.2013, 09:23
Als Antwort auf den Beitrag von Bricks4Jo
+1Re: Dach liegt auf Spannung
ich habe mir gerade die Anleitung angesehen, ich kann aber keinen Verbinder in Tan finden. Du meinst die zweite Anleitung, richtig? Welche Seite meinst Du? WO wird das Teil eingebaut?
Die Zahnradkostrukte von Seite en bis ca. 20 sehen gut aus.
Gerald
XaverG gefällt das
Bricks4Jo
18.10.2013, 09:40
Hallo, ich hab sie jetzt nicht vor mir, da ich auf Arbeit bin und mit dem Handy schreibe... aber vom 2ten Heft der erste Abschnitt mit dem großem Zahnrad auf dass die vier roten Eimer gesteckt werden. In der Mitte dieses Rades kommt eine Achse mit "Verbinder" nach oben und dort kommt das Technicteil in Tan nach oben rein. Dort kommen dann anschließend zwei gelochte 2x? Platten drauf. Ich hoffe ich hab es gut erklärt
MfG
Johannes
18.10.2013, 13:10
Ja ich kann das finden aber nichts in TAN. Ich denke Du meinst das Konstrukt mit der 5.5 Achse. Die steckt unten in einer 2 x 8 Platte und oben mit Verbinder und Achse 2L in zwei Techic Lochplatten (2x8 und 2x4)
...nahc 10 Minuten...
Ich habe mir das mal nachgezeichnet in MLCAD. Dabei ist es wichtig dass die Achse 5.5 auf der Bodenplatte ankommt. WEnn das kleine 12-Zahnrad soweit wie es geht raufgeschoben wird, dann kommt die Achse nicht auf die Bodenplatte an und es steht über. In der BA sieht man das nicht besonders gut, da wäre einen 1:1 Ansicht gut gewesen, aber einfach die Achse reindrücken das geht
schau mal:
Gerald
Bricks4Jo
18.10.2013, 17:34
Hallo, dass Bild ist sehr gut, Danke. Doch musste ich feststellen, es ist ganz unten.
So schaut es bei mir aus. Das Tan Teil drückt von unten dagegen und hebt sichtbar den 1x2 Stein an. Auch mit der dunkelblauen Fliese die noch oben draufkommt, wird es nur wenig besser.
MfG
Johannes
XaverG gefällt das
Hopihalido
19.10.2013, 01:38
ich habe mir das Set heute auch zugelegt (10 Jahre Lego Store Hamburg und auf Schnäppchen gehofft, aber .. )und auch das Problem das es sehr auf Spannung ist, es läuft zwar alles leichtgängig, und wenn das Dach drauf ist sieht man davon nix mehr, aber da unter ist es leicht gewölbt.
Gruß Olli
www.STEINHANSE.eu
it's not a brick, it's Lego
XaverG gefällt das
19.10.2013, 02:14
Interessant, da scheint ein Unterschied in der BA zu sein.
Die Online Version zeigt dort wo Dein Tan "Axle-Pin" ist eine 2er Achse...
Der Axle Pin hat einen kleinen Wulst in der Mitte. Der ist etwas höher und wird daher auf die obere Technic Platte drücken und diese unter Stress setzen.
Tauche das Teil mal gegen die 2er Achse.
Hier ist die Anleitung online:
http://cache.lego.com/bigdownloads/buildinginstructions/6080364.pdf
