11.06.2013, 11:36
+1PaB-Wand Köln
Da die brickbuildr-Seite leider weder aktuell ist, noch die aktuellen Maße hat, hier ausnahmsweise meine Liste vom vergangenen Samstag:
2 x 2 basic dark blueisch gray
2 x 2 Slope 45° trans-clear
1 x 1 plate trans-red
2 x 2 tile yellow
4 x 6 plate red
2 x 4 basic black
1 x 2 grille pearl gold
1 x 4 basic yellow
1 x 2 tile lime
1 x 2 Hinge Plate 1 x 2 Locking with 1 Finger On End sowie with 2 Fingers On End
, light blueisch gray
2 x 6 basic white
3 x 4 x 1 1/3 windscreen tans black
1 x 1 basic orange
1 x 1 plate round trans dark blue
1 x 1 plate round lime
1 x 4 basic red
2 x 2 basic green
2 x 8 basic white
2 x 2 basic white
1 x 1 plate trans yellow
4 x 2 1/2 x 2 Vehicle, Mudguard with Arch Round dark blueisch gray
2 x 2 Plant Flower
1 x 2 basic bright pink
1 x 2 slope 45° orange
1 x 6 basic yellow
1 x 2 basic green
2 x 4 x 2 windscrren trans clear
1 x 6 basic yellow
1 x 1 plate round trans yellow
1 x 2 grille white
1 x 2 slope 45° yellow
2 x 4 wedge plate black left/right
2 x 4 basic dark blueisch gray
2 x 6 basic tan
1 x 2 Plate, Modified with Handle on Side black
2 x 2 tile red
1 x 2 basic blue
1 x 2 slope 45° red
1 x 8 basic white
2 x 4 basic blue
1 x 4 tile reddish brown
Tire 24 x 14
Wheel 18mm D. x 14mm (Tread Small Hub) light blueisch gray
2 x 2 basic lime
2 x 4 basic yellow
2 x 6 basic red
2 x 2 plate orange
1 x 1 basic lime
2 x 2 basic orange
2 x 2 with Pin and Axle Hole dark bleisch gray
2 x 8 basic blue
1 x 4 x 2 Fence Paled (Picket) white
1 x 2 blue
2 x 3 slope 33° invers black
1 x 1 cone trans red
1 x 2 griss black (?)
2 x 4 basic red
2 x 4 basic lime
2 x 2 basic yello
1 x 1 slope 33° trans orange
1 x 2 basic reddish brown
1 x 4 basic green
2 x 4 basic light blueich gray
2 x 4 basic tan
1 x 2 lime
1 x 1 plate round trans red
2 x 2 basic red
2 x 2 round red
2 x 6 yellow
4 x 4 plate blue
2 x 2 Plate, Round with Pin Hole and 4 Arms Up reddish brown
1 x 1 plate round orange
Plant Flower Stem green
1 x 4 basic reddisch brown
2 x 8 basic black
2 x 4 basic medium blue
1 x 2 yellow
2 x 2 x 2 Mülleimer dark blueisch gray
Plant Flower Small, Sprue of Four, red
1 x 2 basic trans clear
2 x 4 white
2 x 8 red
sitz red
1 x 4 plate lime
1 x 2 tile bright pink, nur noch Reste
2 x 3 basic orange
2 x 6 plate reddish brown
4 x 10 plate black
1 x 4 basic orange
antenne black
1 x 1 plate round light trans blue
1 x 4 basic lime
4 x7 7 leiter light blueisch gray
1 x 6 basic red
2 x 2 basic reddish brown
1 x 4 plate red
2 x 2 panel trans clear
2 x 3 basic black
2 x 6 blue
2 x 6 light blueisch gray
Dirk1313 gefällt das
acarstens
11.06.2013, 12:24
Re: man könnte ja wenigstens 60 Teile reinbringen ... besser als eine 4 Wochen alte Liste.
Schön, dass du entscheiden kannst, welche Teile keinen interessieren....
Sinnvoller wäre es, dem Betreiber von Brickbuildr mitzuteilen, dass sich die Größe der Wand verändert hat.
11.06.2013, 12:25
Re: wieso trägst du die Teile nicht gleich auf die Brickbuilder-Seite ein? Mach doch einfach selbst (ohne Text)
11.06.2013, 12:30
Hätt ich gern getan. Allerdings hat er keine Mengenangaben geschrieben...
Außerdem wußte ich nicht, was er mit "nicht die richtigen Maße hat" meint...
Ich dachte ja nur, bis der Betreiber der Seite das ändert, dass zumindest etwas aktuelles drin steht...
11.06.2013, 14:37
schreib überall voll hin. Das passt weitgehend.
Graete
11.06.2013, 15:25
Re: PaB-Wand und Handy
Gute Idee, die Mobilseite wirst Du kennen.
Jau, so in der Art. Ich stelle mir das eher als Mischung von der "normalen" Internetdarstellung als Abbild der realen Wand und der mobilen Darstellung der einzelnen Fächer vor.
Mit der möglichkeit die einzelnen Fächer mit neuen Inhalten zu versehen.
Und als App wird das ganze dann auch schneller, weil nicht mehr alle Daten online bezogen werden mussen sondern die meisten Funktionen lokal auf dem Handy liegen.
In Falle Köln nutzt das eh nichts, weil die Wandgröße geändert werden müsste.
Ich glaube da solltest du dann den Betreiber vom BrickBuildr kontaktieren, dass sich die Abmessungen der Wand geändert haben...
Ich hätte da einen Vorschlag für eine App mit der man sowas dann auch ändern... ;)
Graete
http://www.brickshelf.com/gallery/Graete
11.06.2013, 16:15
update gemacht
So,
ich hab mal die wichtigesten Sachen geupdatet:
Rausgelassen hab ich die, die nicht klar waren, zB. "2 x 2 round red", weil ich nicht wußte, ob es "brick", "plate" oder "tile" sein sollen.
Außerdem hab ich die Bricks in den Standartfarben und die 1x1 plates und Käseecken in trans-irgendwas weggelassen...
... weil es diese Teile schon ewig an scheinbar jeder Wand gibt und die sicher kaum noch wen vom Hocker reißen. Wenn einer in Köln vorbeikommt und die Wand mal in echt sieht und sich an meiner Praxis stört, möge er es ändern.
Grüße von 495km von der PAB-Wand entfernt,
11.06.2013, 16:52
Re: update gemacht
Oh je, ja, Brick, round 2 x 2.
Walton
11.06.2013, 17:12
+1Re: PaB-Wand Köln
Hallo Thomas!
Danke für Deinen Einsatz.Jedes Teil sollte genannt werden auch wenn es den ein oder anderen nicht Interesiert.Es gibt immer Leute die sind froh den oder den Stein zu finden auch wenn er für andere nicht interesant ist.
Walton
PS. Nicht jeder hat ein Handy ;)
legodesinger gefällt das
11.06.2013, 17:46
Re: update gemacht
Hallo Michael,
vielen Dank
Soviel Einsatz wo Du doch vermutlich kaum in den Kölner Store kommen wirst - sehr löblich
11.06.2013, 21:22
Re: update gemacht
Ich hab ihn zuungusten des "1x4 brick, red" reingenommen, weil ich denke, dass es den runden nicht so oft an der Wand gibt, aber in deiner Liste sind noch mehr, wo nur die Größe und die Farbe steht, bzw. die Räder und die redd.brown plate 2x2 with 4 axles (das ist doch das neue Baumelement) finde ich in der Liste gar nicht.
Aber seis drum, die vorhandenen 60 Plätze sind voll, jetzt kann nur noch der Betreiber der Seite helfen.
Gruß Micha
