mhuffman
09.04.2010, 06:08
New iPaB Feature
I wanted to announce a new feature to iPaB. Now on the summary page for each LEGO store, you can download the PaB summary page to a CSV file. This feature comes to you from a suggestion by Ronald -- you have him to thank.
So for instance, on the Frankfurt store, at the top there is a button to 'Download wall (to) CSV'. There should be room underneath each part description to make notes as to 'in-stock', 'empty', or the new part it's been changed to.
Unfortunately, the part names/descriptions are in English... but I have made some changes to the database to allow for German names/descriptions. My next task is to allow for a German version of the CSV file, but I need help translating the name/descriptions... in the mean time, I can work on making internationalizing changes to the web-site.
I have a request to allow for a 'LEGO store' blog, for lack of a better term; that allows anyone to make comments as to what new at their local LEGO store.
There's a request mark multiple containers as 'in-stock' or 'empty'... I like to get that one done this weekend if I have time.
--Mike.
hunter19
09.04.2010, 07:08
Re: New iPaB Feature
Dear Mike
In my humble opinion it would be better to leave the descriptions in English to allow for consistency with Bricklink.
Kindest regards + thanks a bunch for your effort!
hunter19
» I wanted to announce a new feature to iPaB. Now on the summary page for
» each LEGO store, you can download the PaB summary page to a CSV file. This
» feature comes to you from a suggestion by Ronald -- you have him to thank.
» So for instance, on the
» Frankfurt
» store
» There should be room underneath each part description to make notes as to
» 'in-stock', 'empty', or the new part it's been changed to.
» Unfortunately, the part names/descriptions are in English... but I have
» made some changes to the database to allow for German names/descriptions.
» My next task is to allow for a German version of the CSV file, but I need
» help translating the name/descriptions... in the mean time, I can work on
» making internationalizing changes to the web-site.
» I have a request to allow for a 'LEGO store' blog, for lack of a better
» term; that allows anyone to make comments as to what new at their local
» LEGO store.
» There's a request mark multiple containers as 'in-stock' or 'empty'... I
» like to get that one done this weekend if I have time.
» --Mike.
inof
09.04.2010, 08:53
Hello Mike,
Personally I also think that English part names are sufficient. As someone else noted, BrickLink's part names are also in English and people got used to it. Even if there was a German translation, I would probably continue to use the English version in order to avoid confusion when switching between brickbuildr and bricklink. Also keep in mind: The more languages you support, the more involved it gets to keep all of them up to date when new things are added.
This is very useful, so I can easily import it into my own programs. Thanks to both of you!
By the way, it happens quite often that several different parts are put into the same PaB container. For example, just recently they have put two different kinds of black parts into one container of the Munich store. I'm aware that this would be rather difficult to implement with the current design of your web app, but I thought I'd mention it anyway. Maybe you've got an idea how to do this.
Best regards
Oliver
09.04.2010, 11:40
...in deutsch?!
...danke für die Info.
Aber wer kann mir das übersetzen?
inof
09.04.2010, 11:59
Re: ...in deutsch?!
Hallo Michael,
» ...danke für die Info.
» Aber wer kann mir das übersetzen?
Mein Beitrag enthielt eigentlich gar keine Infos, insofern ist es eigentlich nicht notwendig, ihn im Detail zu übersetzen. Ich habe mich im wesentlichen nur bei Mike und Ronald bedankt und einen Verbesserungsvorschlag gemacht. Außerdem habe ich darauf hingewiesen, dass es meiner Meinung nach aus verschiedenen Gründen wenig Sinn ergibt, die Teilenamen auf brickbuildr ins Deutsche (oder irgendeine andere Sprache) zu übersetzen.
Oliver
ROTERACHTER
09.04.2010, 13:05
Mal ne Frage zu IPaB ?!? Warum fehlt immer noch Duisburg??? (ohne Text)
Technix
09.04.2010, 13:09
Re: Mal ne Frage zu IPaB ?!? Warum fehlt immer noch Duisburg?
Weil du es noch nicht erkundet und eingetragen hast.
mhuffman
09.04.2010, 14:11
» Personally I also think that English part names are sufficient. As
» someone else noted, BrickLink's part names are also in English and people
» got used to it. Even if there was a German translation, I would probably
» continue to use the English version in order to avoid confusion when
» switching between brickbuildr and bricklink.
Just trying to make it easier, but if that's the general consensus I'll leave it as is...
» » I wanted to announce a new feature to iPaB. Now on the summary page for
» » each LEGO store, you can download the PaB summary page to a CSV file.
» » This feature comes to you from a suggestion by Ronald -- you have him
» » to thank.
» This is very useful, so I can easily import it into my own programs.
» Thanks to both of you!
» By the way, it happens quite often that several different parts are put
» into the same PaB container. For example, just recently they have put two
» different kinds of black parts into one container of the Munich store. I'm
» aware that this would be rather difficult to implement with the current
» design of your web app, but I thought I'd mention it anyway. Maybe you've
» got an idea how to do this.
Yes, I've been thinking about this problem... There's been mention of a few stores in the US that do this as well. I'm thinking about creating an 'exceptions' table in the database. From the summary screen, you would indicate that a container has more than one part contained within it... then like normal, you'd select which parts they are. Then I'm thinking on the summary page, the 'exceptions' would show up in a separate table below with X,Y coordinates for each exception.
It's not a pretty solutions, but it might work.
--Mike.
ROTERACHTER
09.04.2010, 14:33
Bin am 14ten wieder in Duisburg (mit meinem Sohn zu den Clubtag) mal schauen was sich machen lässt.
Dazu auch gleich ne Frage. Ich weis noch das sich letztens in Duisburg in einem Fach bis zu 5 verschiedene Steine befunden haben. Wie kann man das bei IPaB eintragen?
inof
09.04.2010, 15:11
» » Personally I also think that English part names are sufficient. As
» » someone else noted, BrickLink's part names are also in English and
» » people got used to it. Even if there was a German translation, I would
» » probably continue to use the English version in order to avoid confusion
» » when switching between brickbuildr and bricklink.
» Just trying to make it easier, but if that's the general consensus I'll
» leave it as is...
Well, it's just my personal opinion. I'm sure there are people who disagree.
» » By the way, it happens quite often that several different parts are put
» » into the same PaB container. For example, just recently they have put
» » two different kinds of black parts into one container of the Munich
» » store. I'm aware that this would be rather difficult to implement with
» » the current design of your web app, but I thought I'd mention it anyway.
» » Maybe you've got an idea how to do this.
» Yes, I've been thinking about this problem... There's been mention of a
» few stores in the US that do this as well. I'm thinking about creating an
» 'exceptions' table in the database. From the summary screen, you would
» indicate that a container has more than one part contained within it...
» then like normal, you'd select which parts they are. Then I'm thinking on
» the summary page, the 'exceptions' would show up in a separate table below
» with X,Y coordinates for each exception.
» It's not a pretty solutions, but it might work.
Yes, that sounds like it would work well enough.
Thanks again for creating iPaB! This is something that many of us have waited for.
Best regards
Oliver
Hümpfch™
09.04.2010, 20:41
Re: Mal ne Frage zu IPaB ?!? Warum fehlt immer noch Duisburg??? (ohne Text)
Weil ich von Duisburg keine Bilder gefunden habe und es bisher ja niemanden aus Duisburg interessiert hat, ob die Wand gelistet wird.
http://www.1000steine.de/...um_entry.php?id=190986
Günzburg fehlt auch noch.
Ronald
treczoks
09.04.2010, 21:02
Nice to see that the PAB got more features - but when will it get more fields?
The Cologne Brand Store has about 100 different parts in the wall (usually three different parts in a bowl).
Yours, Christian
mcjw-s
29.05.2010, 19:54
PaB Wand - Merlin - Heide-Park Soltau
Moin, moin,
wollte mal Neuigkeiten von der Wand der Lego-Store im Heidepark Soltau posten, aber auf der Seite konnte ich die Wand nicht finden.
Im Store gab es z.B. die Bioncle - Bälle in orange-silber für diese Druckluft-Pistole, glaube die wurden hier mal gesucht ( könnte Bilder hochladen ) sowie ganz oft die Minifig Vol. 2, dafür keine der anderen.
So, die Wand:
1x4 Fliese: braun,
2x2 Fliesen: gelb, blau, blau-dunkel, tan, orange, blau
2x2 Stein: lime, braun, gelb, rot-dunkel (bordot), blau-hell, grau-dunkel, grün,
2x3 Stein: lime, braun, orange, weiß, grün, grau-dunkel, grün,
2x4 Stein: lime, weiß, rot-dunkel (bordot), blau-hell, schwarz, orange, grün-dunkel, tan, weiß, pink-hell (glaube Farb-Code 104 bzw. 222 ), bau, grün,
2x4 Platte: schwarz
2x6 Platte: grün,
außerdem in blau: Platten 2x10, 4x4,
gelbe Blumen (4728) und 2x4x2 2Rundungen (4744)
grüne Stiele und Kreuz-Blumen (4727)
Bei Bedarf Foto´s.
mfG
Manfred
