02.06.2016, 08:22
02.06.2016, 08:43
Offizielle Stellungnahme - 42056 LEGO Technic Porsche
Zitat TLG
Thank you to all our dedicated fans for the comments regarding the GT3 RS by LEGO Technic.
It is correct that the gears in this model are not sequential as in the real Porsche PDK. This is however, a deliberate decision taken to ensure that we make the best possible LEGO version of this amazing car that both meets our design requirements and gives everyone a great building and product experience.
It was a considered decision taken during development that the gears running in the correct order meant that it did not result in a great experience when driving the car. Too many gears are engaged at the same time and smooth running with all those tolerances is just not possible.
If you switch the build in steps 267 and 269 the gears will run sequentially, and everyone who feels that this is the better solution should feel encouraged to do so.
LEGO Technic really is the ultimate open source design product and now that it is finally available, we look forward to seeing all the 'improved' models our fans create. After all, that is what LEGO building is all about.
We hope everyone will have a great building experience and feel a strong sense of pride from creating both our version and their very own LEGO Technic representation of a Porsche GT3 RS. We are very fortunate to have such skilled and dedicated fans that can spot this small deviation from reality and would like to thank everyone for sharing their ideas and expert knowledge.
Zusammenfassung
Es sei richtig dass die Gänge im Getriebe nicht wie im Original sequenziell angeordnet seien. Das sein aber eine bewußte Entscheidung gewesen um sowohl Designerfordernisse als auch den Anspruch an ein tolles Bau- und Produkterfahrung zu ermöglichen (direkte Übersetzung)
Man habe wohl beim Design des Fahrzeugs festgestellt, dass die richtige Ganganordnung das Spielerlebnis negativ beeinflusse, da dann zu viele Zahnräder gleichzeitig im Spiel seien und durch die erforderlichen Toleranzen ein einwandfreier Lauf nicht gewährleistet werden könne. Jeder könne aber natürlich selbst entscheiden ob er das Getriebe umbauen möchte. usw.
Warum es an manchen Stellen, wie im Online-Shop, zu Verzögerungen in der Auslieferung kommt wird nicht erläutert.
EDIT:
Ich möchte nochmal darauf hinweisen dass es sich um eine Stellungnahme von TLG handelt. Gleichzeitig gibt es schon Vermutungen dass es sich vielleicht um eine "Ausrede" handeln könnte. AFOLs die sich auf LEGO Technik spezialisiert haben sagen, dass die Belastung der Zahnräder bei beiden Varianten gleich sei. Ich kann das nicht beurteilen und kann eben nur die Stellungnahme weitergeben. Wir werden ja sehen ob sich in späteren Chargen dieses Sets irgendwas ändert
Bernd the Brick
02.06.2016, 17:02
Re: Offizielle Stellungnahme - 42056 LEGO Technic Porsche
Danke, dass es überhaupt ein offizielles Statement gibt, auch wenn es wenig zufriedenstellend ist. Aber irgendwie ist es scheinbar jedesmal dasselbe beim Shop, dass ein vielgewünschtes Set nicht rechtzeitig auf der Webseite steht.
Ich wollte eigentlich gestern auch eins kaufen, hab aber zum Glück vorher hier reingeguckt. Ich hoffe, dass ich noch eins abbekomme, inzwischen egal ob mit oder ohne korrekte Schaltung.
Was mich auch etwas stört ist, dass man ein Set, welches noch nicht erhältlich, aber schon gelistet ist, nicht auf seine Wunschliste packen kann.
Bernd
Nichts ist unbaubar.
LuDaCriSoNe
02.06.2016, 19:54
Man könnte echt denken, die bei Lego sind ganz schön dumm. Der Release war ja schon länger geplant und trotzdem passiert es immer wieder, dass irgendwas nicht stimmt. Ich finde das einfach nur Peinlich. Ich dachte die hätten mal aus ihren Fehlern gelernt. Aber es häuft sich immer mehr...
Carrera124
02.06.2016, 20:41
Als Antwort auf den Beitrag von LuDaCriSoNe
Der Fehler in der Anleitung kann ja durchaus passieren. Aber wie man danach den Shop gemanagt hat (bzw. eher nicht gemanagt hat), das war schon dilettantisch.
Anstatt den Verkauf gleich komplett zu canceln - zusammen mit einer kurzen sinnvollen Erklärung und einem neuen Datum - herrscht Chaos im Online Shop. Erst "demnächst", dann waren ganz kurz Vorbestellungen mit Lieferung in 30 Tagen möglich, und jetzt ist ausverkauft... und das Verkaufspersonal in den Stores hatte scheinbar überhaupt keine Infos und hat munter verkauft. Was logischerweise schon die ersten Ebay Spekulanten auf den Plan gerufen hat, die das Set zum Fantasiepreis und mit dem dramatischen Hinweis "limited" anbieten. Die werden sicher ein paar Ahnungslose finden, denn im Shop steht ja "ausverkauft"...
Grüße an meinen Stalker
Knicky
02.06.2016, 22:44
Ja, die gehen für um die 500 € bei eBay weg. *seufz*
LuDaCriSoNe
03.06.2016, 09:53
Als Antwort auf den Beitrag von Knicky
Es dürfte eben nicht passieren. Für sowas gibt es doch eine Qualitätskontrolle! Die nimmt bei Lego leider immer mehr ab... Fehler beim Druck, Qualität der Steine lässt nach (brechen) und immer wieder Fehler bei neuen Set's. Bei dem Piraten Schachspiel hatten die doch auch Probleme.
Vielleicht wirft Lego einfach zu viele Set's auf den Markt!?!
Wer 500€ für den Porsche zahlt und dann auch noch glaubt der wäre Limitiert, ist einfach nur dumm
Picard
03.06.2016, 10:19
"Lustiges" Online-Shop Erlebnis - 42056 LEGO Technic Porsche
über Limitiertes / Specials / Sammlersets / Seltenes etc. wird ja hier oft geschrieben und auch ich hatte in den letzten Jahren auch mitdiskutiert.
Ich habe zum Porsche-Set schon den Hype gerochen und finde es witzig, dass ein Fehler in der Produktion/Entwicklung des Modells nun genau auf den Hype trifft und dazu der schon immer überforderte Lego-Shop es jetzt gar nicht mehr im Griff hat.
Zu meinem Erlebnis: Ich wollte über meinen privaten VIP - Account zwei Porsche am 1. Juni um 8.30 Uhr erwerben, einen für mich und einen für meine Firma als Preis für eine Tombola zum Adventsbasar (ursprünglich wollte ich mir einen auf den Dachboden legen, aber ich will das Spekulieren doch nicht anfangen). Dies ging nicht, da pro Haushalt nur einer zu bestellen war. Da habe ich über unsere Firma als Gast eine getrennte Bestellung gemacht. Diese wurde aber auch storniert mit dem Hinweis, dass pro Haushalt nur einer zu bestellen war. Trotz anderer Firmenadresse und scheinbar nur, weil in der Lieferanschrift mein Name zusätzlich als Empfänger stand, wurden die zwei getrennten Bestellungen innerhalb von Minuten miteinander in Verbindung gebracht. Löblich daran: Tricks von Spekulanten wird so Einhalt geboten. Irritierend: Das mein privater Name mit einer abweichenden Firmenbestellung in Minuten in Verbindung gebracht wird und zu einem Storno der Bestellung führt.
Danach erst bekam ich dann den Hinweis sowohl an meine VIP-Adresse, als auch an die Gastbestellung meiner Firma, dass es zu einer Lieferverzögerung kommt. Das die Firma auch einen Lieferverzögerungshinweis bekommen hat, ist nun wieder komisch, da ja diese Bestellung storniert war.
Nun geht's noch weiter: Seit es dem Shop gibt, bestelle ich dort und habe sicherlich schon eine beachtliche Summe dort geleistet. Nun wird mir aber die Zahlung mit Rechnung verweigert (neben dem Porsche habe ich noch ein paar neue Star Wars - Sets bestellt) und soll den Shop kontaktieren. Auch meine Firma darf nicht die vom Shop stornierte Bestellung auf Rechnung zahlen.
Ich glaube ich storniere jetzt alles und kauf die Star Wars Sets beim jeweils günstigsten Online-Händler und warte mal ab, was aus dem Porsche in den nächsten Wochen wird.
Picard
LuDaCriSoNe
03.06.2016, 11:01
Als Antwort auf den Beitrag von Picard
Re: "Lustiges" Online-Shop Erlebnis - 42056 LEGO Technic Porsche
Das mit Zahlung auf Rechnung ist doch bekannt. Mal funktioniert es und beim nächsten mal wieder nicht. Das liegt am System vom Shop.
Hab erst letztens was für 150€ gekauft (Zahlung via Rechnung) und danach wurden 70€ via Rechnung abgelehnt. Ich zahle sonst immer mit Kreditkarte und die haben an mir sicher schon paar tausend € verdient. Jetzt mit Paypal ist eh alles besser. Unkomplizierter geht es nicht mehr.
promobricksDE
03.06.2016, 11:27
Ich habe heute Morgen die offizielle Stellungnahme von LEGO Deutschland bekommen, ist auf den ersten Blick allerdings mit der aus dem LAN identisch. Kein Wort zur Verfügbarkeit, etc.
http://www.promobricks.de...911-gt3-rs-42056/16664
Gruß, Michael
Gruß, Michael
https://www.facebook.com/Promobricks
Lego3723
03.06.2016, 20:45
Die grössten Kunden scheinen bei TLG gleichzeitig auch die schwierigsten zu sein.
Fan's wollen das perfekte Produkt!
Das geht nicht nur TLG so, sondern allen die ein emotionales Produkt verkaufen.
stephan76
06.06.2016, 09:53
Hallo zusammen. Gibt's denn schon weitere Informationen zwecks Verfügbarkeit ?
Grüße Stephan
Stephan
